Can Damaged USB Ports be physically replaced by Soldering
Both the USB Ports in my MacBook Air are damaged and not working/detecting due to bent pins inside, so can they be replaced by soldering
both ports on either side?? Can you take a photo and upload it?
@danj is the macbook hardware expert IMO... he'll reply to this thread shortly with any additional insight.
The main logic board port might be replaceable by someone with very good skills. It is not something a DIY person can do and could be expensive and risky! You maybe forced into getting a new logic board if it goes badly.
As you have both ports damaged the I/O board would be cheaper to replace and just live with the one working port MacBook Air 11" (Mid 2011) I/O Board and here’s how: MacBook Air 11" Mid 2011 I/O Board Replacement
crwdns2886500:0Replace the I/O Board (input/output board) compatible with the Mid 2011 model A1370 MacBook Air 11 inch laptop. Includes the MagSafe power, USB, and audio port.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$29.99
Arun, also make sure you get the right daughter board for your MBA as the different versions moved the microphone cable and speaker cable so lengths change. (I've done this before and was annoyed because I didn't notice the small change in detail till too late)
Arun Nayak crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 140
