Hi @atlakeem ,
Check in BIOS > Startup > Boot and see if there is a HDD0 listing for the boot order.
If it is there try highlighting it (select it) and check if it shows up in a disabled list on the screen. If so enable it. I think that you do this by pressing Shift + 1 (the ! key) although I’m not 100% sure with your model that this is how to do it.
Hopefully this will restore the HDD in BIOS. When it has been disabled in the boot order it is no longer available to BIOS. This feature is for when people wish to use an external drive only and not have an internal HDD
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2944067:08crwdne2944067:0
Hi @atlakeem ,
Did you install the SSD with a 7mm to 9.5mm adapter (supplier example only)?
The spacer is required so that the SSD is in the correct position and connects securely to the sata port in the laptop. Usually an SSD is only 7mm and it is sitting in a drive bay designed for a 9.5mm HDD
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
It looks like this ssd original came with this computer. It has a thermal shield around
crwdns2934271:0crwdnd2934271:0 Akeem Scrubb crwdne2934271:0
@atlakeem
Have you tried another known working SSD in the laptop to check if the sata port is OK and it is recognized at least in BIOS?
No, I'll try that as my next step
@atlakeem
Maybe try a HDD instead.
That way you can listen for it to spin up when the laptop is turned on. That way at least you know power is being supplied to the HDD.
If you can't hear a HDD spin up (or feel the vibrations of it spinning) then what is the motherboard's board number? (printed on motherboard itself it might be a Wistron motherboard but the model number and version is important e.g. Wistron LCL-1xxxx?)
You may have to get the schematics for the motherboard to find out why there is no power to the HDD.
If there is power to the HDD it may be a sata controller issue
