How do I unenroll a used school/business chromebook leveno 300e?
So I was on eBay right? And I was looking for a laptop for a family member, And he pointed at a cheap chromebook I saw on eBay and he said “I had that chromebook for school and it worked really good!” so i bought it. A couple weeks later it came in, We opened it and set it up but then randomly it started enrolling. And we tried everything I could find online but yet nothing worked. Please help!
So the system grow some legs and found its way to you. Sadly, you need to return it and get your money back ASAP! As its a little on the warm side!
You can’t undo this!
Thank you! I just noticed that the page that has the chromebook i bought on it said no returns. I will keep trying other methods and see if they work.
@natelovesfrogs - Well that makes sense ;-{ they knew it was hot and couldn't be used. Contact eBay to complain! You should be able to get your money back, as you where ripped-off!
old post, but whatever. if you already got your money back, good on you! but here's what you could've done:
First, powerwash the Chromebook. Sign in to the internet and when you get to the screen where it says “Getting device configuration” click the notification center in the bottom right corner and get ready to turn off the wi-fi. When the screen turns to “Enrolling device” Turn off the internet. It will say “Enrollment Failed” Then click the button “Enroll manually” This should pull up a screen saying “no internet”. Turn the internet back on and click the back button. Eventually, in the bottom left corner, buttons will start to appear. First, Apps (If your district has apps). Second, Browse as Guest. When Browse as guest appears, go back and forth clicking the back button and the Browse as Guest button. Eventually, the Chromebook should crash when you click browse as guest. Finally, press ESC + refresh + power and it will take you to a screen where it says “Chrome OS is missing or Damaged” Press Ctrl + Search (Ctrl +Shift on older models) and then press enter to go into developer mode. Then, the screen will say “OS Verification is off. Press space to enable” Press space to enable then press enter. Finally, the Chromebook will reboot and the enrollment should go away. If it doesn't work, then try it again.
hey how long dose it take for the buttons to appear (Browse as Guest)
So what is when I get to the point where I click enroll manually and no internet, I turn the internet back in and there is no back button? When do I do then?
Nathan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 598
