My laptop power ic not working
My laptop power ic is not charging I have checked battery health its fine changed the adapter and found out adapter was also fine now the only thing that has the problem is charging ic. Where can i find the replacement??
You need to find the IC number on you motherboard in order to find the replacement. You may also search for schematics for you laptop to find out the IC number. Might be other components that stops your IC from working.
