Why did my whole audio system stop playing except front speakers?
I recently purchased the Kenwood KMM-BT325 bluetooth media player for my car audio system. When I first got it installed I just ran it on the internal speakers that were already in my car. Later on I purchased a Memphis Audio Amp with 600 watt PEAK and a good sub. After I got it installed I was so happy with everything. It sounded amazing and it was not to much so I did not attract unnecessary attention. Well about 2 months later when I turned my car on my amp would not kick on I would have to turn it up really loud to get it to start hitting then turn it down. Then I noticed the actual radio would turn off and back on sometimes when I push the next song button. Then everything went out except the radio and the 2 front speakers. So i was looking at the wiring and everything cuz i thought it might be my amp but when i looked at it while my car was on and the amp's light was on so it is for sure getting power but the sound from the sub and back speakers is not playing at all.
This sounds like either something is wrong with your Memphis amp or there's an issue with the preamp signal going from the Kenwood deck to the amp. You can try running new RCA signal cables to the amp to rule out bad cables. Also check the Kenwood's menu settings - some decks have a low/high setting for the preamp outputs that might have been accidentally changed. There might also be an internal amp on/off setting in the deck that is affecting the preamp outputs, as well as attenuate/mute settings that can affect the preamp outputs. If nothing seems to fix the problem, then it might be in the Memphis amp. You can troubleshoot by disconnecting all your current speakers and testing each individual channel's output with a new test speaker. But you'll need to confirm the preamp signal is getting to amp correctly first.
LeeAnna Townsend crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 102
