My Mackbook Pro will only boot in safe mode
My Late 2011 Macbook pro only boots in safe mode. To do this I have to first press the power key for 10 seconds, then connect the power cable and release the power key after 6 seconds and press shift key while the booting starts. If I dont press the shift key the laptop wont finish booting and instead would be stuck in an endless reboot cycle.
Please help solve this situation
Thanx in advance!
Hi Thushar,
That is most likely caused by a third party program causing the computer to crash constantly and in your case, to not being able to boot in normal mode.
When your Mac boots on safe mode it prevents third-party programs to load, so we can safely assume something you installed recently is causing the issue.
Go back to any programs you might have installed or updated recently, and either roll back the updates or uninstall them and see if that fixes the issue.
In any case, I would recommend backing up all the important data while you are on safe mode, so in case you can’t figure out what program is causing the issue you can reinstall a clean version of your OS.
Hope this helps!
More likely your discrete GPU has failed. This was a common issue in this series. Try to find a 2012 logic board with a minor alteration to the LVDS cable it’s a direct drop in!
Thushar Ravi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,490
