This device is a personal paper shredder manufactured by Fellowes, Inc. in 2005. The shredder has the capability of shredding 7 sheets of paper at once as well as credit cards, identification cards, and cards likewise of the same thickness.
What are the gear part numbers?
The primary and secondary gear teeth are stripped, do you have any idea what the part numbers are? I’ve looked everywhere I can think of. Thanks!
I had a look around and couldn’t find any part numbers for the gears. The best thing you can do is count the teeth, measure the diameter and thickness and check if you can find a similar gear is a specialty shop that sells gears. Do note there are different type of teeth, so also pay attention to the form of those.
What are the "tenths" that you're referring to?
I've only counted teeth so far (12/50). Once i get the dimensions, do you know of any sites that are set up to search by dimensions?
Thanks!
Oops, I meant teeth there. I've seen this website passing by in some other forums https://www.hpcgears.com/ but I think if you know the diameter & amount of teeth you could do a google search with that and get some results to sites that have advanced filtering.
Hi, I've helped others reproduce damaged plastic gears that you can't buy anywhere. Please message me and I'll be happy to help you. https://www.ebay.com/usr/krunkz
@mrmaster8300 self promotion on here is consider SPAM. Please feel free to add your services to your About page but not in Answers. You can refer from Answers to your About page but not to any outside link that will promote your business. On the about page it is okay to give more details about what it is that you do and your specialty, NEVER IN ANSWERS! and NEVER ON THE GUIDES
caleb.peacock crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 260
