USB C ports non functioning at all.
Is there any way to replace these parts so i can charge it again?
Hi,
You may be out of luck as far as easy replacements are concerned as the two USB-C port are hard mounted on the motherboard.
Are the ports physically damaged at all?
If not then it may still be a software problem and it may be easier to temporarily replace the battery with a fully charged compatible replacement battery and check the status of the USB-C ports rather than removing the motherboard and to replace the USB-C ports as they may not be faulty.
Here’s the hardware maintenance manual that may help with either option that you decide to go with.
I had one c drive fail. It was covered under warranty. They replaced the motherboard. Apparently not uncommon problem. I WATCHED part of a one and half hour video as someone repaired the port with welding equip or something. It was not an option for me.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 578
Hi
Have you checked the status of the USB-C ports in Device Manager, you didn't say?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
its dead atm cause i cant charge so i cant check, its a gen 5, for some reason this option is not avalible , any replacement parts?
crwdns2934271:0crwdnd2934271:0 Yahir Nava crwdne2934271:0
