Battery drain, TouchID dead, warm display/LCD in locked mode
Hi all,
I have an issue with my iPad Air 2:
A few weeks ago, I did drop it. But as I remember it did still work fine for a few days.
But then, from one day to the next, it started to drain battery very quickly (in locked mode, screen off, it goes from a full charge to 0% in about 3-4 hours).
I then realized that TouchID didn't work anymore, but the home-button is functional.
The LCD display gets warm to the touch (even if locked for 1-2 hours) in the lower right corner (not directly above the home button).
I opened it up and disconnected the home-button as well as the digitizer/touch-glass. I only left the LCD connected. In that configuration the battery drain still happens and again the LCD gets warm in the lower right corner, while the battery/logic board area stays cool (I left it open with LCD flipped to the other side, so I am sure the display gets warm, not the logic board).
I guess I would have to buy a new LCD, but that is quite expensive.
Does anyone have an idea how I can further narrow down the root cause before ordering a display?
Thanks
Perhaps the drop loosened a component inside the display, but it had no adverse effects for a brief period?
I did order a new screen. The first one I received worked fine in terms of display and touch, but the home button was completely dead.
I got a warranty replacement sent - that one finally worked fine (including home button and touchID)
So it was indeed the display unit that was causing the battery drain and touchID to stop working properly.
Max Mueller crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 99
