Epson's L220 is ideal for home and home office users looking for good-quality, ultra-low-cost printing, scanning, and copying. Released around 2016.
crwdns2934591:09crwdne2934591:0 crwdns2934593:0crwdne2934593:0
crwdns2934055:0crwdne2934055:0
"Multi-page feed error" keeps popping up with my Epson L405 Printer.
(The don’t have an Epson L405 option) Every time I print a document with multiple pages the multi-page feed error would keep popping up and I have to press the copy button every time to continue printing again. I tried setting the default document size the same as the document’s size and the error still pop-ups.
Sorry for my bad English :)
Does the "Multi-page feed error" message appear on your computer screen or on the printer's display panel?
It appears on the computer screen
If the error appears in your computer and not on the printer itself, the issue may be the printer's driver. Try uninstalling the current printer driver and then installing one from Epson's Website at the link below:
https://www.epson.com.sg/Ink-Tank-Printe...
I uninstalled and installed the driver again, it didn't work D;
It could be that many pages were fed to the printer at once. Try removing all the printer paper from the tray, putting it it back, and then pressing the color button on the printer.
Even I had the problem with my L485. The only solution is to keep less number of paper in the feeder and check if the paper's corners are not bent
i have same problem with epson l3150 ,everything else work fine but in double side printing it gives error -multi feed error but there is no paper stuck ,if i print odd/even print then it works fine
crwdns2942667:0crwdne2942667:0 1,382
