Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
Boot loop flashing apple logo
I have a defect iPhone 11 Pro Max that didn´t show any signs of life. I could get it into DFU mode and also Recovery Mode with the screen detached. I bought a Replacement Screen and now it shows recovery mode on the screen. When I try to exit recovery mode i get stuck in a booting loop where the apple logo would flash and then it shuts down again. I was wondering if anyone had a similar issue? Restoring won´t work by the way (Errorcode 4013 in 3uTools). Can someone confirm this has to do with NAND ic? Or could it also be caused by faulty batterie or lightning port?
Error 4013 can be caused by a lot of things but mainly the NAND. It is caused by a loss of USB connection. The first thing to do with a phone like this is to completely rule out parts. You can do this by installing the logic board into a known good housing with a known good battery.
Once you have confirmed it is not a parts issue you would move to the logic board.
We have several external battery chargers and keep most iPhone batteries in stock. It is an easy matter for us to plug in a fully charged battery without having to do as much disassembly to check for the same thing
Toby crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 561
