The Ninja Professional Blender 1100 watt model BL663CO, is a high-performance blender used for ice crushing, blending and pureeing.
crwdns2934591:014crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Accidentally plugged into 220V outlet.
I accidentally plugged this blender to 220V..what should I do.?as of now..it’s not working..turns out its broken..how can i repair.?or just need to replace fuse.?if yes..what kind of fuse?thank you!
crwdns2942205:01crwdne2942205:0
Hi. Were you able to get it fixed? If yes, how did you fix it please? I'm currently in the same situation. Looking forward to your response.
Hello, the first thing you need to do is to replace the fuse, the rated voltage is written on it. But you can bypass it momentarily with a wire to check if everything works fine, which I do NOT RECOMMAND, especially if you’re not familiar with electronics.
The varistor in mine blew (yellow circle) 10s271k and can be replaced with 10d271k (blue circle)
Ampong Bicol crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 742
