It is possible that this is a sensor issue. I used to have a Toyota van that would disable stability control and traction control if the mass air flow sensor was unhooked, a misfire arose, or if a wheel speed sensor was reading too far out of spec (bad alignment). Best bet would be to get an OBDII code reader (you can find basic ones at places like Walmart for ~$25 and bluetooth ones for a bit more than that online), hook it up, and see what codes come up. You can then look up the code number you get along with your car model on google and should be able to find common causes of the code.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
