Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
crwdns2934591:0143crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My HDD is not detected. I want to recover data that's in it.
Hi,
I had a laptop on which I had stored some very important document. The laptop’s HDD failed and I cannot access the files no more.
The HDD is Fujitsu FKL-MHZ2320BH G2.
I have a SATA reader to USB cable. I have tested the cable with another internal Laptop HDD and it works fine. But when I try to plug in that failed HDD, my Linux machine doesn’t even detect it. No output to the following commands: lsusb, lshw, lspci.
But the HDD makes rattling noise and the lights on my SATA reader casing displays show everything is normal.
Please tell me if I can I fix it with software? Or is the hardware damaged, that will need professional help? The data is sensitive and I’d like to recover it myself if I can. If so, please tell me how. Thank you.
If you want the data, stop trying it yourself.
Each time you try to power on a broken hard drive, you diminish your chances of getting the data back and certainly drive up the cost of data recovery.
Data recovery needs professional equipment and skills. I won’t tell you how, because if you need to ask, you can’t do it now and you will destroy the data.
Go ask professional data recovery services.
Annada Behera crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 30
