Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
Wifi greyed-out even after replacing antenna
Hello everyone,
I just bought a second hand iPhone 7 knowing that its wifi would not work but since I had another iPhone 7 which wifi is working properly I thought to switch the pieces (speaker/wifi antenna).
However, the wifi remains greyed out, bluetooth works. What can I do to fix this?
Thank you :)
If Wi-Fi is greyed out you have a board problem and not a parts problem. You will need to replace or re-ball the Wi-Fi IC. If you replace it you will have to unbind its Address from the NAND. This repair will require the correct equipment and experience in microsoldering.
Hello,
Thank you very much !
I'll dig into that NAND problem as well as microsoldering which I know nothing about ahah.
Thanks again !
KasDing crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 201
