hello Fxguy1,
unfortunately, repairing iPad, contrary to appearances, is neither easy nor safe for it. Originally simple problems are extended by careless technicians to the limits of profitability of repair. Most damage occurs at the stage of removing the motherboard - this is after attempts at unauthorized repairs. Currently, there are no documentation and diagrams of modern iPads in the public space, so the amount and quality of knowledge on this subject is quite limited. However, this does not prevent a few people with experience and knowledge of microelectronics freely navigating the topic with amazing efficiency. To answer your question: yes, a start-up voltage is required to run iPad pro 9.7, via the main power manager (PMU) - colloquially speaking: a battery is required to start the iPad. Powering iPad through the lighting port is one of many option, but other conditions are still required, including connected power through the battery port, in the PMU environment. It sounds confusing to people with little knowledge of iPad repairs, but it's really not difficult. Simply put - knowledge about it is essential. My advice is to take your iPad to a good repair shop. If you can solder microelectronics, ask for a diagnosis. On its basis, you will be able to continue your adventure with iPad repair - which I urge you to do.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
