Status LED Description
Green (blinks slowly) Charging normally
Off Charging finished
Green (blinks quickly) Error
I would suggest to use a AC charger and not the USB from a computer. If your battery is discharged to low the USB port will not supply enough amperage to charge the battery. I would definitely start with a new battery, and an external charger. That way you know for sure what works, especially since this is a "refurbished" camera. You could look at places like this for your parts. Good Luck
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
Have you checked out the battery? It is possible that you battery does not charge. does it blink a pattern or does it blink continous? Have you checked your power supply to make sure it is charging. Use a multimeter on your battery contacts to see what you get
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
its not the battery because i checked online and when i connected the camera to the outlet power supply it blinks repeatedly for a short while, and that means that there is an error on the camera. how would i get a multimeter and check the battery.
crwdns2934271:0crwdnd2934271:0 Christian Quan crwdne2934271:0
Make sure your software for camera driver is up to date, I've had this happen when there was a mismatch with camera/driver
crwdns2934271:0crwdnd2934271:0 pollytintop crwdne2934271:0
