Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
I spot darker side surround the screen on my iPhone display
This happened after I replaced my battery and I follow through all the instructions and it was successful.However after put all the thing back,and turn on my iphone I spotted this greyish dim spot surrounding my iphone 7 plus display.I am curios if the opening suction cup put much pressure on the display when I try to open the screen and cause tension to the backlit lcd? Has anyone experienced the same problem like this?
Aftermarket batteries will often do this, even occasionally causing the screen to flicker around the edges (especially when the phone is low on battery). If it doesn’t get any worse I would say it’s just due to the battery and shouldn’t really be any cause for concern.
Hope this helps!
No sir.The shadow surround the screen always stay there when I look for them. Sometime they change a bit and then went back to normal (the shadow spot). And it can not be notice if you just using your iphone like a normal person would. The shadow surround the screen can be spot when you trying viewing the screen from the different angle. I am sure this is not a flickering problem nor battery problem.what do you think?
admwitchy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 118
