The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
crwdns2934591:0306crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Xbox is possessed by something
I have a limited Starwars R2D2 Xbox 360 slim edition with Dream Theme RGH installed.
By pressing the tray then blue screen it indicates I have RGH system.
So, it sometimes(most of the time), blipping noises by itself, turning on by itself, opening tray by itself, closing tray by itself, and turning off by itself. Just like a living real R2D2. The blipping sound is quite annoying. (I don’t understand you R2D2, please speak human language, I yelled when I got mad)
Sometimes, it obediently let us play the game just fine till we are done. but lately, it keep turning off/restarting to home screen by itself after awhile after entering the game.
What I tried, I disassembled the xbox, and clean all the dust and stuff inside, not sure how clean it is, I suppose it should did the job better than before, but I was wrong, it doing it again.
So, what should I do? I want to disassemble it again, or should I prepare a strong blower first?
Just flimsy touch buttons, either due to dirt, broken touch cable or electromagnetic interference.
What should I do? Disconnect the tray cable? Would it cause any problem? Since I don't use the CD tray
so, when I open the shell of the xbox, there are thin paper black-colored wire thing that connected to "tray button" and "power button" both are welded so I don't know how to open those. I afraid I might not be able to put it back once it got removed from the plastic-welding.
First check if there are obvious damage/kinks on the flex cable, then is there any possible interference coming from the front accessory board. Finally check if bad power supply/wall outlet is causing interference and ghost touching.
Only the flex cable is easily replaceable, if you can't solder plastic, maybe replace it along with the faceplate.
thanks, I will see what I can do about it
Ahiung Lim crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 179
