Yellow spot on my screen after back glass replacement
Hello. I have replaced the back glass for my iPhone xs Max and after the replacement I have two yellow marks on the screen, top right corner next to battery and bottom left. I replaced in the same day the back cover for an iPhone X flawless and now my xs max has this. Will attach pictures
Thanks for the answers. Can I fix it witouth replacing the screen, or it will get worse ?
crwdns2944067:05crwdne2944067:0
Any pictures?
crwdns2934271:0crwdnd2934271:0 Roman Prochazka crwdne2934271:0
[image|2251791][image|2251967][image|2251966][image|2251965][image|2251964][image|2251968]
While the screen is off you can see in the last picture that the defect is still present. A weird thing that happens is at the last white bar of the WiFi signal, when I look straight at it is yellow, if I look from an angle its normal white.
I am thinking is a glue/something problem because underneath the actual oled pannel seems to show colours just fine
crwdns2934271:0crwdnd2934271:0 Cristian crwdne2934271:0
Done, I uploaded the pictures @pomikoli
Have you replaced just the back glass or the entire back housing? Have you used any heat or glue while the screen was still attached?
@pomikoli i have used heat, only back glass, stuck the phone to the table using two strips of two sided tape stuck on a tape and that on the screen . I had slight issues when trying to get the phone unstuck but did not use excessive force. And yes the screen was still attached. I did not use glue, it came preapplied. Due note that the defect looks like a yellowish spot under the glass, the colours are good when looking at it from the side, or even upfront. So I don't think that the actual oled is the issue.
Used the exact same procedure on an iPhone X 30 mins prior, it worked flawlessly. Both phones work great, beside those two spots, touchscreen, touch id, NFC wireless charging nothing else affected on either of phones.
