cpu block screw nut disconnected from N551W motherboard
My laptop had an accident lately and its CPU start to heat up so fast so I opened it and saw that two of CPU block nuts disconnected from motherboard. I resolderd them but they disconnected again. I tried to resolder them for 4 or 5 times but again they disconnect so quickly. How can I make them to stay in their places and not to fall out? Is there any special adhesive use for this purposed?
both shown nuts are disconnected, blue one was resolderd when I took the photo but disconnect in les than half an hour
It’s a bit fiddly, but finding the right size screw/nut&bold is better than any glue. You want to give it something to latch onto from the under side. This is that way I normally do it for long term results when the proprietary fitting is beyond repair. The issue your going to have with glue is both pressure and heat.
I was thinking about adding longer screw and nut at the back of pcb but i have some serious issues founding some right size nuts. My laptop has fan problem too ( magnetic levitation not working) and i couldn't find any replacement for it and I can't import because it will cost so much and I afraid this will happen again for nuts.
I should look at electronic dumpster.
Thanks for the answer
Best regards
Matin sadroddin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 220
