The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
Small tab came off during reassembly
The small brown tab that clamps the ribbon cable for the back case onto the motherboard just popped off while I was putting the cable back in. Attached are pictures of the tab,
the ribbon cable on the back case,
and the pins it fits into
(the white slot) does this go back on and if so how? I have large fingers and can barely see what I’m doing. Does the cable work without it being clamped down/can I just tape the cable in the slot? The disasembly guide on here could really use an overhaul, it just says to reverse the steps, but getting things back together is much different than taking it apart. That and it skipped steps relating to the ribbon cables.
eric jiga not it will not work without it. Well, not properly anyway. That little tab holds down the cable to make proper connection with all the contacts in that connector. You’ll find if you do not use it, the display will most likely not work. That tab is really hard to see but some of those have little bumps on the ends that insert into the connector. You’d need to post a macro picture of this to see it :-) .
Worst case scenario would be having to replace the connector. It is possible but requires some pretty good skills and tools to solder it on.
Is it possible to push the pins down manually without the tab? And do you think the tab can be re-attached since I still have it? Thank you for the help.
try to reattach it but be careful. They do not bend easy and love to break. No, there will be no pressure to close the contacts on the connector with the latch. I know it does not seem like much but it will really no close the circuit. Sometimes it works for a bit just to fail again
eric jiga crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,055
