Repair and information details for the GE Refrigerator GSH25JFX****, a side-by-side model with an automatic defrost feature and an anti-sweat heater switch, released in 2010. This page covers information for model numbers matching the pattern GSH25JFX****.
water dispenser not working.
My GE side by side refrigerator will not dispense water out the door. When you push the paddle you can hear the switch click but not a drop comes out. The ice dispenser works and the ice maker is working. The water supply is reaching the ice maker and the filter must be good for water flow to reach the ice maker. Ay suggestions?
Update (10/27/2020)
2011 ge side by side model# GSH25JFXBB. thanks, jim
Hi @buchele ,
What is the model number of the refrigerator?
Hi @buchele ,
Check that the water inlet valve, for the water dispenser is working. (see part #800 - Machine Compartment parts diagram for location)
Your model has two water inlet valves, one is for the ice maker and the other one for the water dispenser. When you operate the switch at the dispenser, it signals the control board to operate the valve allowing the water to flow.
The supplier in the link was only selected to show you what the part looks like (note the dual valves) and where it is located.
If the valve is faulty there are other suppliers online that may suit you better. Just search for GSH25JFXBB parts to get results. Alternatively search for WR57X10032 (this is the part number). Here’s another image that shows which valve is for used for the ice maker and which is used for the dispenser i.e. ice and dis
(click on image to enlarge for better viewing)
james buchele crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 206
