Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
crwdns2934591:0468crwdne2934591:0 crwdns2934593:0crwdne2934593:0
After repairing of water damage a proplem with camera sync with flash
After water damage with my iphone xr , the teq clean it but i faced proplem with rear camera sync with flash , that camera took captuer before flash , that result with dim pictuer
how can i fix it
with regards
This is not uncommon for water damaged phones. While the technician managed to clean the device enough to allow booting and general operation, in your case there is still something wrong with the camera/flash circuitry or modules.
I would start by removing the front camera (battery first!) to see how just the rear camera behaves with the flash. If that doesn’t help, then you will need to try a new or known-good rear camera to see if this is a “parts” problem, if not then there is a problem at the logic board level that will have to be looked at by a micro-soldering tech.
ezeno.doc crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 43
