The Ninja Mega Kitchen System BL770 is a complete kitchen appliance manufactured by SharkNinja.
Replacing broken plastic gears
Our Ninja BL700 stopped spinning. I disassebled the unit and the plastic 3 gear unit at the top had shredded teeth not allowing the unit to spin. Ninja does not offer a replacement part but saud I can purchase a replacement base. Does anyone know where I can purchase the part. An internet search has not been fruitful. Thank you.
The person that answered your question isn't DIY savvy. You tore your unit down to find the 3 gear cluster inside the white casing. Apparently this is the main failure in the Ninja brand. I'm also trying to find a replacement, but you're the closest I've come to finding anything online.
If you are talking about the gear-looking part on the drive shaft that meets with the bottom of the blade assembly, it is called a coupler or coupling. I haven't found one for Ninja, but there are a lot for kitchen aid and waring around. I would wonder if one of these is 'compatible'.
Example: https://www.ereplacementparts.com/coupli...
Update (10/17/2020)
Similar question: The flexable rubber coupler has broken..
In that, this guide is referenced which includes a rebuild of the planetary gear assembly. I see now this is what you really needed
https://sites.google.com/site/dgeake51/h...
No. It is the gear unit that turns the coupler.
Broken 3 gear unit that turns the coupler.
Tim Strickland crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 2,302
