The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
LCD showing multiple of the same image after rebuild
I was fixing a broken screen/digitizer on a 6th gen iPad and now have issues with the LCD after rebuilding it. Your guide was great. Minus dealing with the broken glass, I had no major issues disassembling the iPad and the reassembly was easy. Things went wrong though when I turned the iPad back on to check to see if the new screen worked. The LCD was now showing multiple of the same image. There’s also a white bar near the top of the screen. I’ve attached a photo so you can see what I’m talking about. I was super careful with the LCD when I removed it and don’t recall bending it or putting any other significant force on it… however, I’m not ruling out that maybe I did. Is my LCD hosed or is there something else I can try to fix it? Thanks
Take it apart and inspect the display connectors and cables for damage. By the looks of it you did leave a few fingerprints on the LCD but that’s not a huge issue as you can gently wipe them off. Anyways if the connectors look good I would try another LCD. If a new LCD still shows the same problem them you’ve probably got a board issue on your hands and it will need to be repaired by a microsoldering specialist. Did you make sure to disconnect the battery and put something under the board between the battery before disconnecting the screen?
Connectors and cables look good. I did disconnect the battery as shown in the guide. I will try a new LCD and see if that works. Thanks.
Ryan Glaske crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 75
