An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
Why is my Smok X Pozz not charging?
I’ve looked everywhere and I can’t anyone with my specific problem on my specific device. I have the Smok X Pozz 10 year anniversary edition and whenever I try to charge it, it’ll recognize the charger for a few seconds, then the battery UI goes up and down on charge level, then cut out or flicker back on for a few seconds. I’ve ruled out the chargers and the charging port seems fine. Anyone have suggestions or should I just move on from this mod?
First, you have to check if there is 5V on your board (somewhere near to USB-port).
If there is no voltage, you should replace micro-usb port.
If there is voltage, try to clean all board with IPA.
gabriel gregory crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 463
