The Lenovo IdeaPad 110-15ISK was developed in the United States by Lenovo in 2015. The Lenovo IdeaPad 110-15ISK can be identified by its model number: 80UD.
No battery detected with adapter plugged in
I recently did a clean install of windows after replacing the hard drive after it was done I noticed there was a message that said battery not detected to test it I unplugged the power and immediately shut off. Before all of this I know for sure it was working without the ac plug. I have double checked that I plugged everything back into place.
Hi @louie77,
Try the following:
Go to Device Manager >Battery > right-click ACPI compliant entry > uninstall then restart the laptop and check.
If it still shows as not detected, create a Win 10 battery report and check what it says.
If still not there open the laptop and check the connections again. I know you said that you double-checked before closing but….
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
Thanks I tried everything and once again checked the battery connection and forced it a bit more and surprise, it powered on with out the AC plug
I changed the battery to a new one but it still says no battery detected and I also uninstalled the drivers from device manager but still got thesame no battery detected,. Please help
Hi @tizzerblog,
Did you do the Win 10 battery report as @jayeff suggested?
https://www.windowscentral.com/generate-...
Louie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 31,604
