2 different dryers not drying clothes! Help!
When I moved into my condo it had a washer and dryer already in it. I had to dry clothes 5 times just to dry one load. So I bought a brand new hotpoint dryer from HH Greg and the same thing is happening. It still takes drying clothes 4-5 times. I had a warranty and HH Greg came out and said there is nothing wrong w the dryer or the vent. They cleared the vent part that goes to the outside. (They either blew or sucked the space)
they didn’t leave me with any answers. Can someone help!?
Hi @kerilouwho ,
What is the model number of the dryer?
Is the dryer heating up or only staying cool?
Try disconnecting the exhaust pipe at the dryer, for just a few minutes. With the dryer running, you should feel warm, moist air coming out. That would prove that the dryer is working and the problem is with the exhaust. If the air is cool, the heater in the dryer is defective. If no, or very little, air comes out, something is plugged up with lint or the fan is not working. Either way, this will require a bit of investigative work. Good luck.
@kerilouwho not sure where you are located but since this is not your dryers issue as checked by the techs, I suggest that you check the outlet. If you do not have enough power on it you will not get the heat. LEt us know what country you are located in. That way we can determine what the household voltage is supposed to be. You also want to let us know what the exact make and model of your dryer is.
Keri crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 265
