Hi,
The water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components. The corrosion starts immediately and doesn’t stop until it has been properly cleaned away.
Rice does not fix the problems cause by corrosion Rice is for dinner, not repair
Do not try to charge or to turn on the phone and then remove the battery as soon as possible so as to minimize any further problems.
Next you need to disassemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb, be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Also remove any shields that may be covering some components and clean there as the water may have got in under them as well. The ends of any cables and their connectors will also need to be cleaned. If the battery appears to be swollen it may be safer to replace it.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit Motorola Moto G4 Plus guides that may help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
Please reply ASAP please ...
crwdns2934271:0crwdnd2934271:0 Metal Skull crwdne2934271:0
Can someone please tell me how long will it take for the corrosion to render my smartphone useless... Please answer ASAP
