The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
RGB light strip 5,1 Mac Pro
I have a mid 2010 Mac Pro 5,1. I want to put a RGB light strip in it,
I read an article that said this: “The factory fans of the Mac Pro are quite decent, if you [only want to add RGB to your Mac], you can install an LED strip that has a SATA connection and RF remote control to change the color of the strip. You can get power from the SATA cable of the second optical drive bay, and if you happen to have both bays used you can use a Y cable”.
So I bought this RGB kit from amazon: LED RGB PC Light Strip - Speclux Computer Magnetic Addressable LED Strip Kit And this Y cable StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M / F
The MOBO SATA connector on the Y cable I bought is not quite the right fit. I attached some pictures of what I mean. I would think the answer to this question is simple - lol !!
What cable do I need to get to set this up properly and where, thanks Nick.
https://imgur.com/5gEik3E
https://imgur.com/QyZmvk4
https://imgur.com/j0kzDD3
https://imgur.com/v4YwFmv
https://imgur.com/nbTlWek
https://imgur.com/oJcPyw3
https://imgur.com/moVIZ1w
@nberns1 just get an original Apple HDD harness cable and use that in conjunction with your cable to make the cable you need. Something like Apple part number Apple 922-7682 should work for this
nick bernstein crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 845
