Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Touch screen not working even after replecement.
My touch screen problems started by a home button not working. After that my touch screen started to fail randomly. It wouldn’t work but after a night without touch it it would respond for only a couple of seconds and then dead again. I replaced the screen (I did it right, it was not my first repair) but the new screen still not responds. I’m prone to believe that there is some kind of motherboard issue. Did anyone had a similar problem and fixed it?
This is a signature fault on the 6 plus. There is a trace under the touch IC that becomes broken from the phone flexing. To permanently fix the problem the touch IC needs to be removed and a jumper wire installed, you can than put the touch IC back.
If you wanted to try and get a bit more life out of it you could try and put some packing on top of the IC so there is some pressure on it. You would have to search YouTube on this.
Yes replace the motherboard or replace the touch chip on it.
Francisco Parada Larrosa crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 55
