The Lenovo Yoga 2 13" can convert from laptop to tablet, tent, or stand mode with hinges on the side. It was released in January 2014.
crwdns2934591:038crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Does this laptop have only soldered RAM? Is it not upgradable?
I’ve also just pulled the bottom cover off to take a look and it seems there may be some room for a secondary SSD/HDD in addition to the included M.2 drive.
Am I understanding this correctly? I don’t want to futz around with it much before knowing what’s possible.
@printedwaffles the RAM cannot be upgraded. The Yoga 2 13 has 2 slots: 1 m.2 (that is now used for your SSD) and another connector for a 2.5"  storage device. For some models this is a normal SATA connector, but for most it is a very rare SFF-8784 connector that only connects to the 5mm WD HDD. Found these for part numbers ZIVY0 HDD Bracket : 90205123
ZIVY0 HDD Cable WD : 90205124
Thank you. I was a bit confused after opening it up. There seemed to be some unused space that could potentially fit a laptop drive, but I didn't see a SATA style connector around.
Thanks for the part numbers! I'll be exploring this further.
Too bad about the RAM. Silly Lenovo.
Man, looking these things over, it seems like a ridiculously obscure way to go about adding storage space. It might end up cheaper just getting a larger m.2, and certainly less time consuming.
Again... Silly Lenovo.
Alberto Einsteino crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 227
