@jcewl93 Fluids and Capacities are as follows
Fuel
3.7L/4.7L, 87 Octane 22 Gal.
Engine Oil (with filter)
3.7L, SAE 5W-30, API Certified 5 Qt.
Cooling System (includes 2.1 Qts./2L for coolant bottle 3.7L (Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula) 13.3 Qt.
The total fill requirement for the four-speed automatic transmission is 8.8 qts., and 17 qts. with the five-speed unit.
Automatic Transmission Mopar ATF+4, Automatic Transmission Fluid.
Manual Transmission (Getrag 238) Mopar ATF+4, Automatic Transmission Fluid.
Transfer Case Mopar ATF+4, Automatic Transmission Fluid.
Front Axle SAE 75W-90 Multipurpose Type, GL-5 Gear Lubricant (MS9763).
Rear Axle SAE 75W-140 Synthetic Gear Lubricant (MS-8985). Limited-slip rear axles require Mopar limited-slip additive (MS-10111). Four ounces (118 ml) should be added to the gear lubricant whenever a fluid change is made.
Brake Master Cylinder Mopar DOT 3 and SAE J1703 should be used. If DOT 3 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids.
Power Steering Reservoir Mopar ATF+4, Automatic Transmission Fluid.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
4
