Half of Screen messed up
I have had the akaso ek7000 4k ultra hd since christmas 2019 and it is having a problem now. When i turn it on half of the screen is like blue transparent. What could be causing this?
Tyler Sawyer could be a bad screen or a bad connector. You do want to see if you can reseat the connector, making sure all the pins are clean and straight etc. If those are correct, try a new screen.
Just be aware too … the drivers for the screen are part of the firmware, so you can't use just any LCD screen (if you are replacing a broke screen)
if you update the firmware - with the wrong version, this will also cause problems - since the driver won’t match
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 214
