No WiFi or Bluetooth after replacing battery and speakers
I’m not sure where to begin looking for the problem. Can someone point me in the right direction? I have no Wi-Fi or Bluetooth after replacing the battery and speakers on my MacBook Pro 13 inch retina late 2012 laptop. I followed the tutorial exactly and did not seem to have any problems during the repair.
Either the I/O board cable or the I/O board its self has an issue
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
Here’s the guide MacBook Pro 13" Retina Display Late 2012 I/O Board Replacement
crwdns2886500:0Replace an I/O board compatible with the Late 2012 or Early 2013 MacBook Pro 13" Retina laptop. Fix problems with display, and data connections. Includes the USB, HDMI, and SDXC ports.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$34.99
crwdns2886500:0Replace an I/O Board Cable compatible with the Late 2012 to Early 2013 MacBook Pro 13" Retina laptop. Fix the connection between the I/O Board and the Logic Board.crwdne2886500:0
I’m an amateur here so I really appreciate your time. I made sure all cables were reconnected properly. In your opinion should I proceed with replacement of the recommended items? I was extremely careful when I replaced the battery so I don’t think I damaged anything. Are there any other things I should check first? The only other ‘symptom’ before I replaced the battery was occasional difficulty getting the laptop to connect to a Bluetooth speaker. It would sometimes take multiple attempts to connect with no apparent cause. Thanks again.
Try reseating the I/O cable, if that fails replace it and test again.
Will do thanks!
I’m having this same issue. Did you solve it in the end?
@henrychugh26 - Did you try resetting the cable and if that didn’t help replace the cable. 40% of the time reseating fixes it and the other 40% replacing is needed. And lastly 20% the board is corroded up.
Angela Desjardins crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 656
