https://www.laptopscreen.com/
almost all modern laptops use either a 30 pin LVDS cable or a 40 pin LVDS cable in order to connect to the display (except for Apple devices since they use a proprietary implementation of the OBDS protocol which is not compatible with PC’s ) find out which one your device uses then use that website to search for a device that is the same size Meaning whether it’s a 14 inch screen or a 15 inch screen the replacement needs to be the same size as the as your current one as well as the same type of displays meaning LED or lcd (lcd displays Are rarely used in modern laptops these days unless their budget versions LED screens are capable of much better quality in higher resolution outputs, however you can’t go from one to the other So if you currently have an LED screen then you need to purchase an LED as a replacement and vice versa. however you can choose a screen with a higher resolution capability than your current one so long as all of the other aspects I just mentioned are identical. If your current device has a resolution below 192 0 x 10 80p Then your new screen should at least be At or above the resolution I just mentioned it is like day and night when you experience a screen that’s not high definition versus one that is you could also go beyond 1080 P if your graphics is able to handle it if it’s a relatively modern device you can go as high as 4K it’s all about how much you’re trying to spend
You can also dojust typed the model of the computer and every result which shows is a compatible screen that you could go with There are a number of display manufacturers which all produce a variety of identical incompatible displays so that’s why you’ll see a lot of results and variations in Pricebut if you can pull the actual display out and type in its model number it’ll be easier to sift through the compatible devices you have to choose from
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
