Laptop acts like someone is holding down the 1 key intermittently
I’m looking for some advice on how to approach this problem with my laptop. As the title says, my laptop sometimes acts like someone is sitting there holding down the 1 key. If there is a text box active it’ll type 1’s non-stop, and if not it’ll start to mess with the ability to tap to click things using the track pad. Clicking the keys on the trackpad still works though. I’ve had this problem for a while now, so I’ve started to notice it only really starts up when the computer really starts heating up, like when I’m playing games, but I can watch tv for hours without it acting up.
A little bit of background, I did spill juice on my computer at one point, and I immediately turned my computer off and flipped it over. The keys were sticky for a while until I pulled them all off and cleaned them a few times, but there weren’t any other problems for a few months, when this issue with the 1 key started happening. Despite the time delay I’m assuming it’s related since it’s the only damage that’s happened to this computer.
Since this problem has been happening for a while, I’ve tried a few things to fix it, unsuccessfully, and I think I might have narrowed down the problem a bit. I originally thought it was just a sticky key so I pulled the key off and cleaned it repeatedly, along with the area directly beneath the key. When that didn’t work I thought it might be a software glitch so I factory reset my computer. That didn’t help so I’m back to thinking it’s hardware. I’ve pulled the back off my computer but didn’t have much luck getting to the other side of the keyboard, there’s a lot of stuff to take apart and I’m worried I might do more harm than good. As it is right now, even if the 1 key problem starts acting up, my laptop can fold backward (into a tablet sort of mode), which disables the keyboard and the 1 key problem along with it so I can use a bluetooth keyboard instead, but it’s a somewhat obnoxious solution.
I’m trying to figure out if I can fix it myself or if I should send it in to be fixed professionally. Ultimately it wouldn’t be too big of a deal if I broke this computer more while trying to fix it since I have a desktop as my main computer now, but I’m not even sure where to begin taking it apart, I couldn’t find anything specific about this model of laptop and I’m not sure how much I’d need to take apart to get to the back of the keyboard where I’m guessing the problem is. If anyone has any ideas or advice that would be fantastic, thanks for reading.
crwdns2942205:01crwdne2942205:0
To replace the keyboard, follow the iFixit guides for removing the following, in this sequence:
- Back Cover
- Battery
- SSD
- WiFi Card
- Coolant Fans
- Motherboard
This will finally get you access to the keyboard. The keyboard itself is covered in a sheet of black plastic film, you will need to gently remove this black film AND SAVE IT. Also remove and SAVE the small rectangular foam pad (about the size/shape of a postage stamp) on the left side of the keyboard.
Next, you will need to undo the screws securing the keyboard. Good news: They're basic PH000 Philips screws. Bad news: there's 55 of them. Remove all 55 screws and SAVE them for installation.
Remove broken keyboard and replace with new keyboard. Reinstall all 55 screws. Gently re-attach the black plastic film from before, ensuring that it covers all of the screws. Remove adhesive backing from the ribbon cable and fold it over and attach. Attach small foam pad.
Reinstall other components in reverse order of removal.
crwdns2934271:0crwdnd2934271:0 Eli Peter crwdne2934271:0
