Repair information and support for GE Profile Refrigerators.
Why will my refrigerator not turn on?
So I was troubleshooting the refrigerator not cooling but freezer working fine. Found what I think might be the issue the evaporator fan in the fridge. As i was taking the deli drawer apart the plug to it came loose and the wires came un pinned and touched each other! After finding the wiring diagram i re installed the pins in the correct locations. I unplugged the refrigerator and then plugged it back in to reset it but the lights or anything wont come on. The only thing that comes on is the screen on the front door and it only turns on to see the GE symbol and I cant change it to say or so anything else. What do you think the issue might be? Blew the main board after it shorted out or is there a fuse I can look for? Any other way to reset it other than unplug?
My fan motors on my fridge don't come on but the compressor does.
@keithjohansen
What is the model number of the refrigerator?
Which fans are you saying don't come on, the evaporator fan, the condenser fan or both?
Hi,
Shorting out pins if the power is still connected to the refrigerator or connecting the power with the pins still shorted is definitely not good.
The first thing to check would be the control board for any obvious signs of damage, e.g. burnt out components etc.
If you can't spot anything or you're not quite sure post some close up images of the control board back here.
Here's how to do this. Adding images to an existing question
shawnhall10 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 442
