Repair information for the Bose SoundSport in-ear headphones. Released in 2016. Model number: 761529-0010.
Can I cut the left ear-piece off? Bose SoundSport.
I know I will lose the left side audio channel. I normally only listen to podcasts with the right-side earpiece anyway. The wire sheath has ripped and been repaired too many times. Now the left stopped working, and I can do without it (for my purposes).
I assume the batteries are stored in each side for each earpiece independently.
I would cut off everything left of the volume control plastic housing.
Any help will be appreciated.
Yes you can cut the left-side piece. It doesn’t effect you right-side peiece
Thanks - do you know for sure?
Do I need to terminate / isolate the wires left cut?
Hi Chris, did you try this? Did it work?
When you cut that side off, you need to insure the cut wires are not shorting. Since these are wired earbuds, they shouldn't have any batteries in them. They are just connected to the audio output system.
Thank you. I never did cut that faulty lefty off. Good point on terminating the resulting wires.
chris crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 178
