LCD inverter change of a Toshiba
I need to change the LCD inverter from a Toshiba Satellite Radius P554W-B5220 but i haven’t the model of the inverter. Could you give me the model of the inverter?
Hi @hubertoc ,
Are you sure that it has an inverter?
If it is a LED LCD display then it doesn't need one as they are only needed for LCD displays which use a CCFL tube for the backlighting.
