fuel gauge not working
fuel gauge is not working?
This is a pretty common and annoying problem with the Dakotas'. Most likely it is the sending unit. You will have to drop the fuel tank and replace the fuel pump/filter assembly The sender, filter, and pump are all one assembly, so you'll need to buy a whole new pump assembly to change the sender. Of course you can, and should, also check your gauge to make sure that it is working okay. Use a meter to check your sending unit and see if you have any output. If that checks out, its your gauge. Here is a pretty good write up about how to do it....Hope this helps, good Luck.
Sad but true and not cheap. +
Good to know! I looked up the price of the unit (pump/filter assembly)$80-$250, depending on where you want to buy it, etc. I also look up EVERYTHING on Youtube, and it is an easy fix for the Do-It-Yourselfer!
mí Dakota 98 consume demasiado combustible
no e tenido respuesta
What yoh post to set the fuel pump too
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 40,311
crwdns2944067:04crwdne2944067:0
New fuel pump and sending unit...no gas guage function.
Once it read full on an empty tank before I started the engine. After turning key on it went to empty. Gas light is always on with full tank.
Is it possible the wires were put back together backwards?
Same note...occaionally I have to pound on dash pad to get rpm and speedo to work...sometimes NO guages work til I smack the top of dash.
Help please...thanx
crwdns2934271:0crwdnd2934271:0 Patrick DeMent crwdne2934271:0
Okay...got dash to stop turning off...power harness was not connected securely...however...still have gas light on full tank and no guage function. Thinking the float is sticking against wall of tank as it is a new fuel pump and I didn't install it.
Previoust owner's grandfather did all the work on it. Well...drop the tank and see what 's what....
Ssssoooooo…it IS a brand new out of the box unit…what are your thoughts on this delimna?
Is it possible the idiot that installed it had placed the unit in wrong direction and the float it wedged against the wall of tank?
Drinking me insane with full tank and no guage function.
The guage works…it occasionally goes to full when ignition is off. ?????
#\€_:#! ”&\*&&€;:##_&;:” #\_.# anyway!!!
Could be your thermostat is sticking the truck gets hot shuts the ingine off your instrument gages don't show it being hot because the don't work
crwdns2934271:0crwdnd2934271:0 G Mc crwdne2934271:0
