The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
crwdns2934591:036crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Toshiba LED TV no red light, only panel light
My 2 year old nephew accidentally launched his wheel toy at our Toshiba LED TV which is only 5 months since its repair.
Now the red light and green light is gone, I don't know if the LCD is okay as there are no lines indicating a broken lcd. If I plug the TV it will light up a bit, and the panel light stays on but no picture or blue screen coming up the display.
So this is already plugged in, but no red/green light:
When I plug the tv on, this screen shows up for a second:
Afterwards, I can see this faint light which I assume is the panel lights. I angled the photos so that my phone’s cam can capture what I see.
Please help!
Hi @pstch ,
Presumably there is no audio either?
Disconnect the power from the TV and remove the back cover and check for any damage along the bottom edge of the LCD panel and also on the boards i.e. burnt out components etc.
I don’t know Toshiba but it may be that there are ribbon cable connections there that connect from the board to the panel. Post some images back here of anything suspect.
Not trying to alarm but no audio would also indicate a mainboard problem. What internal damage has happened would need to be assessed first, otherwise it is just guesswork.
Be safety aware, there is exposed lethal AC voltage in the back of a TV when the power is connected. Always disconnect the power before working in the back of a TV unless testing and you know what you’re doing.
San crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 227
