Hi @goodboi5 ,
It sounds as though either the battery terminals in the camera may not be exerting enough tension on the batteries when they are inserted or there isn’t a good electrical connection due to corrosion or loose connections
Check that the camera’s battery terminals are bright and shiny and are exerting enough tension on the batteries when they are inserted. Sometimes the problem may be with the battery compartment door not pushing down on the batteries hard enough. Try pressing down on the battery door and turning on the camera at the same time.
If it looks OK and still doesn’t work, maybe the battery terminal connections have been corroded possibly due to leaking batteries in the past.
The camera would have to be disassembled and inspected as to what the cause may be
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
