MY phone is not starting
It got wet and suddenly stopped working and now trrying to start it but not starting
how to fix it kindly help
Fully immerse your phone in a container filled with rice to pull water away from the device. Let it sit for around 24hrs and then attempt to restart your device.
Thanks for the info @jayeff.
Hi
Water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components. The corrosion start immediately and is ongoing until it has been properly cleaned away.
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to prevent any further damage. Even if the phone is off, there is still power available at various points on the systemboard. The phone’s power on/off button is not a power isolating switch. Think of the phone as being in an extremely low power state when it is off rather than being off and disconnected from any power source.
Then you need to disassemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. You will also have to remove any shields that may be covering some components as the water may have got in under them as well. Also disconnect any flex cables and clean the ends of the cable as well as the connectors that they were plugged into.
Hopefully after you have done all this the phone might possibly work correctly again.
Here’s a video that may be of some help as it shows how to open the phone so that access to the internal components is possible.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later. It’s not going to get any better by itself.
crwdns2942667:0crwdne2942667:0 349
