6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Thermal Pads for Phones
Hi guys, so right now I’m doing a screen repair on a Nexus 5X and I’ve realized that there is a thermal pad on the phone’s screen assembly (see picture). I don’t think I can transfer this pad without breaking it so I was wondering which thermal pad should I buy.
Is it fine to use pads that are for PCs eg. GPUS?
Should I be buying 0.5mm thickness or 1mm thickness?
Are AliExpress/eBay thermal pads fine to use.
eg. ++https://www.aliexpress.com/item/32716660...
++https://www.aliexpress.com/item/32839304...
Thanks.
The thermal pad on the screen is the yellow square.
If you have a lot of space use 1mm which would dissipate the most heat but if you only have a limited amount of space then go for 0.5mm and I think you should read the reviews before buying the thermal pads
Hairy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 565
