The Motorola G5s Plus can be identified by its model number: XT1804 (varies based on country). It is an updated version of the 5th generation of Motorola’s Moto G series. Some distinguishing features of this device are its metal unibody design, improved front and rear cameras, and bigger battery.
How to remove Moto G5s Plus screen?
Motorola Moto G5s Plus Display Replacement
I am following this guide to remove the screen from my phone?
I am using an SMD rework station (878ad), instead of a heat gun, and a vacuum suction cup for pulling the screen once glue gets loose from the heat.
I have tried with 125 Celsius temperature (I know it is higher than recommended), and tried heating for 3 minutes. The glue doesn’t get loose at all.
What should I do to open it?
Should I try with even higher temperature, or should I try heating for a longer duration?
My screen is working fine, but I want to replace the speaker (I have a new speaker).
Moto G5s Plus Loudspeaker Replacement
I suggest you try this one instead, since it’s the speaker you want to replace.
As for the heat, don’t exceed the recommended value or things might break. Maybe it should be better if you helped it with a prying tool WHILE heating it.
Already seen this. This also involves removing the screen. The video mentions 100 Celsius for 1 minute. I have already tried with higher values.
Sahil Singh crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 285
