The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
Light bar stays on?
I have a ps4 days of play edition with the matching remote, I checked the model number and based on the fact it has the two light bars I know it’s a newer model remote (I also found out with a fix I tried), I was charging it on a portable charger, which I’d done before with my gen 1 remote, and after a few days of doing that I noticed the remote would tweak. First it started with the ps4 constantly showing it charging even when it wasn’t, then when I unplug it it’ll stay connected normally but if I turn the remote off it thinks that it’s still charging as the orange light on the light bars turns on. If I try to reconnect the controller to the ps4 without a cable the white light will blink once or twice and go back to orange and after repeated tries the light will freeze white. When I plug it in the light goes away and turns orange again and if I turn on the remote it turns on normally and pairs and works fine. At first I thought it could be a battery issue, I haven’t had it very long (6 months max) but I thought maybe the portable fried the battery so I bought two replacements and replacing the battery only fixed the problem that it didn’t have any charge and wasn’t accepting it anymore. I’ve tried pressing the reset button on the back, unpairing and repairing it, I’ve tried everything and nothing works. Help?
Hi! I don’t think this is a battery issue. I think it’s the LED/Charging Port OR the cable which isn’t working as it should. Everything works fine, right? check the board and the cable. How do you charge it normally? Just with the USB cable?
Guide for replacing the LED/Charging port: DualShock 4 CHU-ZCT2U Charging Port Replacement
So normally I do charge it from the ps4 directly, I use the original charging cable that came with the ps4 (have also tried the cable that came with my gold headset since it’s Sony) I thought it might be the port too, and I know it’s probably why it didn’t work, but I tried to put the charging port for a gen 1 remote into it (the one not working is gen 2) the remote detected the charging port and light but didn’t change anything. I don’t want to buy a whole new remote just to take the parts out but I want to continue to use this remote as it’s “limited edition”
Hi Again! Oh, no that won't work. You need the exact same model as the original that came out. Anyway, it's reacting on it when you replaced it, so my bet is that it will work with a new LED/charging board. Those are not expensive too.
I have 3 controllers with this exact issue, did changing the port board worked for you?
Thanks
buddio14 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 257
