Where can I purchase a replacement fan
one of my fans is making a grinding noise. I see there is a guide on here how to replace it but where can i get the fans.
https://www.amazon.com/Cooling-GTX1060-R...
https://www.aliexpress.com/i/33012273436...
Here are some links. Before you proceed though, you should make sure it’s not just built-up dust blocking the fan.
It will potentially save you time, money and effort.
Thanks for this. I will double check the dust but i have cleaned out using air.
No problem Alex :). It could also be hitting a wire, hence the noise. Make sure everything is properly into place and that wires don't overlap where they don't need to.
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,283
