Microwave turned on and my hand was inside
Im concerned because when I opened the for to get my food out after heating it, the microwave turned on and my hand was inside. I quickly pulled it out and shut the door. Now I'm concerned a out it. If it's gonna hurt me because I was exposed to it.
Hi,
Get the microwave oven checked out and repaired.
It should never turn on with the door open if it is working properly, as there are two interlock door safety switches which are supposed to stop this from happening.
If your hand doesn't look burnt it may be OK as microwaves heat the body tissues the same way as it cooks food.
Looking online there seems to be no correlation between microwaves and them causing cancer. Microwaves are more dangerous to the eyes and other more sensitive areas of the body though.
At best everything is OK, at worst you may have some burns but the severity of the burn depends on the microwave power setting at the time and how long your hand was exposed to it.
What is the model number of the microwave oven?
this happened to me yesterday at work, my hand is tingley still. Toshiba microwave, opened the door and it turned on, I thought it was the light only and did not process that the microwave was actually on.
@deenabowers
Get the oven checked out.
Microwave ovens should not turn on with a door open and if operating should turn off when a door is opened
Magdalena Prieto crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,682
